I started machining the parts last week and I am currently single point threading them. As for the thread rolling test I ordered rollers for the largest thread, if the machine doesn't have the power to do the largest one then there is no sense in spending thousands of dollars on a head that can just do a few threads. Single point is working fine and I am using a full profile insert.
Update: The thread rolling head we got would not fit in the machine, it was about 1/8 inch too long and would hit the guide bushing when that station was called up. Sad part is we checked that on the spec sheet and it says it's 1/4 inch smaller than it actually is. So we said the hell with it and we are just going to stick with single pointing. Thanks Brian
I've used an M141 with a "W" in the past on our L20's. Unfortunately this is not an option in our A32, the station I'm using is fixed.
