603,798 active members*
2,429 visitors online*
IndustryArena Forum > MetalWorking Machines > OKK > OKK VM7 III 2007 Cycle Start Button and Spindle
    Hello,
    I have an OKK VM7 iii from 2007 that I bought recently and I just installed.
    One problem I'm having is that Cycle Start button will not light up when pressed in MDI Mode, I've checked the diagnostic screen and there are no alarms or feed hold.
    I believe I may have a door or safety guard switch that will not allow the cycle start to begin.
    Another problem is that the spindle will not rotate at all. In handle mode, when I press CW or CCW it will light up momentarily and then turn off.
    Nov 2007
    365
    Re: OKK VM7 III 2007 Cycle Start Button and Spindle
    Check custom screen and see if you have the Bypass key turned on ?
  1. Replies: 8
    Last Post: 10-12-2024, 06:45 PM
  2. Replies: 1
    Last Post: 10-03-2023, 04:55 PM
  3. Start Cycle Button
    By wsj in forum Mach Mill
    Last Post: 06-25-2019, 03:36 PM
  4. okk vm7 retenton knob fingers
    By drewmeister in forum OKK
    Last Post: 04-29-2008, 02:21 PM
  5. Cycle Start button
    By kaleem1 in forum Mach Software (ArtSoft software)
    Last Post: 12-24-2005, 09:05 PM
