587,848 active members*
3,059 visitors online*
Results 1 to 8 of 8
    Dec 2010
    Unhappy Okuma cadet 4020 mill m&g codes
    I cannot get this machine to run a M98Pxxxx sub program in EIA.
    Machine skips right over the M98 Pxxx command and goes to the next position.
    It also does not recognize the G98 command when drilling tapping. I need to jump over clamps ect.
    It alarms out with alarm# 425 Alarm B unusable g code 62.
    Does anyone have a list of M&G codes for this machine?
    Thanks, Al
    Jun 2003
    205
    Okuma Programming
    You are programming with Fanuc format ... the OSP is different :
    M98 P1234 would be CALL O1234
    No G98 ... you need :
    G71 Z ( this is your initial plane ... this block is prior to your canned cycle call )
    M53 is G98
    M54 is G99
    Hope this helps ...
    Real World machine Shop Software at ... Kentech Inc. - Real World Machine Shop Software
    Want to convert your Fanc programs to OSP ... or OSP ones to Fanuc ??
    Check out CNC XChange from Kentech Inc.
    Dec 2010
    Thank you very much BlueChip. All is good now
    Dec 2010
    What is the OSP command that would work the same as the Fanuc M99?
    I want the program to keep running untill I stop it.
    This is a new (old) machine and I would like to keep it cycling the program it's going to be running for a day or two to see if there are any problems with it.
    Thanks, Al
    Jun 2003
    205
    M99 for Okuma
    The command RTS is used at the end of a subprogram ... like M99 on the Fanuc.
    Real World Machine Shop Software at ... Kentech Inc. - Real World Machine Shop Software
    Jul 2010
    369
    Try this link out
    Okuma Lathe G M codes G-codes M-codes
    Hope this helps you, though its for a lathe =/
    Good Luck~!
    Dec 2010
    RTS works fine for the sub prg. I want to keep running the main program, without having to press cycle start each time. RTS in place of M30 in the main alarms out.
    Thanks again, Al
    Jan 2008
    575
    right before the end of the program. Enter this exactly;
    GOTO N100
    on the second line, at the top of the program enter this;
    N100.
    This will loop the main.
    Robert
    The beaten path, is exclusively for beaten men.
  1. Okuma Cadet Software
    By ryanh114 in forum Okuma
    Last Post: 02-02-2023, 11:51 AM
  2. OKUMA CADET MATE
    By Antonio Arguijo in forum Okuma
    Last Post: 10-09-2011, 02:26 PM
  3. cadet 4020 tool change problem
    By Hash01 in forum Okuma
    Last Post: 11-18-2010, 08:54 AM
  4. ATC Sequence problem Cadet 4020
    By mbm in forum Okuma
    Last Post: 04-03-2010, 07:35 PM
  5. Okuma cadet mate 4020 -OSP700M 1999
    By Taehk in forum Okuma
    Last Post: 06-21-2009, 03:23 PM
