588,562 active members*
5,460 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > osp5020 panel wont turn on
Results 1 to 4 of 4
    May 2009
    91
    i bought a 1996 okuma cadetmate 4020 with an osp5020 controller... the guy i bought it off of says that the monitor went out and he never fixed it.. i powered the machine up today and sure enough the panel wont turn on... no lights or anything turn on when i fire the machine up... any suggestion anyone?
    Mar 2009
    1982
    is there some red LED lit on OPUS panel inside main control cabinet?
    a lot of suggestions.
    You need electrical diagram first.
    Check if there is +24V and -24V - it's easy just on terminals of power supply units.
    Then check contactors and trigger fuses next to these power supply units.
    Finally, check power on button on op panel - must be 24V on contacts. Check connection from the button to cable.
    Dec 2009
    6
    check the power supply inside the op panel
    Dec 2009
    6
    that supply has different voltages output
  1. It wont turn on
    By Farmers Machine in forum Uncategorised CAD Discussion
    Last Post: 11-30-2009, 02:27 AM
  2. Spindle wont turn on
    By KARD in forum Fanuc
    Last Post: 04-21-2009, 12:46 AM
  3. spindle wont turn
    By jkinz56 in forum Milltronics
    Last Post: 06-26-2008, 05:17 PM
  4. SX3 Spindle Motor Wont Turn ON
    By ddexd in forum Benchtop Machines
    Last Post: 02-07-2008, 01:30 PM
  5. Motors wont turn
    By moto21 in forum Mach Software (ArtSoft software)
    Last Post: 09-22-2005, 04:13 PM
