588,254 active members*
5,167 visitors online*
Thread: Outline
    Jul 2003
    148
    Unhappy Outline
    If I import a part from AutoCad, it does not seem to have a surface. JUst the lines that make up the part. How would I go about after I have joined or grouped the lines to get the surface so I can extrude the part as a solid? I can extrude the part as isbut it is hollow inside. Just haveing the extruded lines forming and empty wall. Thanks.
    Apr 2003
    1357
    Make sure to set the option "cap = yes" in the extrude command. The extruded lines will then become a solid.
    Dan
  1. Looking for Eagle head outline g-code
    By CerveloRod in forum G-Code Programing
    Last Post: 06-03-2005, 06:28 PM
  2. Smooth outline and pockets
    By pauls in forum BobCad-Cam
    Last Post: 01-17-2005, 02:02 AM
  3. Circuit-board, design software.
    By ynneb in forum CNC Machine Related Electronics
    Last Post: 08-02-2004, 10:40 PM
