603,310 active members*
2,400 visitors online*
Results 1 to 4 of 4
    Jun 2010
    119
    Output X as Radius???
    I asked this in my other post, but I figured I'd make a new post just for this. My Southbend Magnaturn 1218 needs code where X is the radius. I made sure line 1249 is set to r, but it still outputs as diameter. I looked in Settings, Current Document and changed it to lathe and Radius mode, but that hasn't helped either. Is there something else I need to change somewhere? I've searched everywhere and haven't found anything.
    Thanks for any help.
    Mike
    Jun 2015
    4189
    Re: Output X as Radius???
    hy if you wish i help you with a custom application, that will edit automatically your files, in background
    it requires 0 intervention; it detects your original file, then edits it/ kindly
    Jun 2010
    119
    Thanks, but I'd rather the software I paid for worked correctly.
    Jun 2010
    119
    OK, got some help and found out that 6005 needs to be changed from 2.0 to 1.0 when you change 1249 to r.
  1. Radius to end of arc differs from radius start
    By Don C in forum Dolphin CAD/CAM
    Last Post: 06-29-2014, 04:46 PM
  2. Output radius instead go I and K
    By cob in forum Mastercam
    Last Post: 01-24-2014, 03:54 AM
  3. Replies: 1
    Last Post: 05-15-2013, 08:52 AM
  4. Replies: 7
    Last Post: 10-06-2011, 04:43 AM
  5. radius output from postprocessor
    By peters1980 in forum EdgeCam
    Last Post: 02-09-2011, 11:36 AM
