603,954 active members*
3,301 visitors online*
Results 1 to 5 of 5
    Feb 2008
    4
    Parallel port control software
    Hello
    I've built my own PIC based Stepper driver and I want to test it from the target computers parallel port card which is a PCI card, I have yet to find any PP Control/monitor software out there that will work with a PCI PP card.
    Does anyone know of one that exists. I really don't want to have to program one if one exists.
    Ron
    Jan 2006
    357
    Jun 2003
    3312
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Feb 2008
    4
    Sorry I guess I should have explained more.
    I will be using Mach3 when it is done but for the time being I want to turn on and off bits in the PP's data byte manually, all software that I've seen do this wants an address that is a standard PP address (0x378), I'm using a PCI card that gives me an address of 0xC000, this is not normally usable with the software I've seen.
    Ron
    Jun 2003
    3312
    That's different. Your correct, a lot of software that does parallel port IO in Windows uses inpout32.dll which I don't believe supports more than the old 16 bit IO space.
  1. parallel port cam software
    By mikie in forum DIY CNC Router Table Machines
    Last Post: 11-24-2008, 06:45 PM
  2. Software that uses the Parallel port of a PC
    By rgillard in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 11-21-2008, 01:37 AM
  3. XP parallel port control
    By stormelf in forum Stepper Motors / Drives
    Last Post: 11-26-2005, 06:32 PM
  4. Parallel Port / Relay Control Question
    By Verboten in forum Computers / Desktops / Networking
    Last Post: 12-21-2004, 11:17 PM
