603,930 active members*
4,611 visitors online*
Thread: parameter
Results 1 to 8 of 8
    Oct 2008
    32
    parameter
    hello everyone
    our company bought old machine. the machine had not been run for long time, no battery, lost all parameter, i got cnc parameter and pmc parameter only, but i don't know how to put parameter into machine by hand. another question, the machine can be run, do need additional parameter?
    thank you
    Oct 2008
    32
    the machine system is fanuc 16tb
    Feb 2009
    28
    You say that it runs, why worry about a bunch of un-needed parameters then?
    Oct 2008
    32
    Quote Originally Posted by hawkburger View Post
    sorry,my english is poor.
    the machine stoped, no battery, lost parameter.
    i got cnc and pmc parameter only, but i don't know how to put parameter into machine by hand.
    another question, For the machine can the normal work, but also needs any parameter?
    May 2006
    64
    Hi.
    PMC program did not lost.
    You should take a PCMCIA card. Copy parameter and change the name to "CNCPARA.DAT"
    Put Card into PCMCIA slot on CPU 16TB and read all parameter in to memory.
    Goodluck
    Jan 2009
    22
    Mr hongjianming
    hello
    at the first ,backup parameter have two types. SRAM or CNCPARA,DAT
    just like you say "For the machine can the normal work, but also needs any parameter? "
    it means this machine work normaly ,
    it's no alarm ,
    Machine can cut part ,part also is eligible .
    It that your means ?
    Like that machine is OK,parameter is looks like nomaly.
    I can hlep you put the backup parameter into NC in Chinese .
    mail to [email protected]
    Feb 2010
    46
    Hi First thing that you should do to enter the parameter with Fanuc control is to change the value of PWE (Parameter Write Enable) from 0 to 1 as follow:
    1- Select MDI mode and push Emergency Stop.
    2- Push Setting softkey as many times till you get the page of setting (Handy).
    3- bring your curser to Parameter Write or PWE then input 1, now you can enter all your parameter by hand or any device to your control and as soon as you change the value of PWE from 0 to 1 you will recieve P/S alarm 100, it is normal.
    4- After finishine Para entry, you have to change PWE to 0 then press reset and turn off the machine for 30 sec.
    I hope these information were what you were looking for.
    Karsue
    Feb 2011
    640
    might be a couple years late
    i just replied to one over a year old too, always forget to check the dates...
  1. MV-JR parameter??
    By machine1956 in forum Mori Seiki Mills
    Last Post: 07-15-2010, 05:33 AM
  2. parameter
    By davek in forum Fanuc
    Last Post: 11-08-2007, 02:45 PM
  3. parameter 64
    By swartling in forum Haas Mills
    Last Post: 02-20-2007, 11:57 PM
