603,957 active members*
3,383 visitors online*
Results 1 to 10 of 10
    May 2006
    214
    Parameter changes
    Hello everybody
    I'm ready to start my journey with macro programming.
    My Lathes Miyano's (Fanuc 18TB) need some parameter changes.
    Does enebody know witch ones?????
    Please help.
    Cheers
    Dec 2003
    24260
    I have 9932 bit #7 (1xxxxxxx)for the 18M, I would assume it is the same for the 18T.
    Al.
    Albert E.
    May 2006
    214
    Thank you
    I'll try it......
    I know I have to test it with:
    #101=1
    What is suppose to happen if it works???
    Dec 2003
    24260
    You won't get an error?
    the contents of local var. 101 will =1
    Al.
    Albert E.
    May 2006
    214
    Al-
    I changed it, and test it (#101=1). I get an alarm:
    Illegal addres imput.
    Is this good news??????
    Cheers
    May 2006
    214
    Al -
    Thank you
    I'll keep playing tomorrow.
    Time for a cold one.
    Cheers
    Nov 2005
    219
    dont put it inside of the ( ), if you are.
    just
    #101=1.
    May 2006
    214
    Right -
    When I use 101=1; I get an alarm
    If I do 101=1 I do not get an alrm.
    Anyway now..Ican not found the macro soft key to be ablo to se my variables.
    I think I need the help of Fanuc.
    But if someone outhere has any ideas......
    Thank you all for you replies.
    George
    Nov 2005
    219
    Push the offset button and then press the right hand arrow soft key. It should be on this page as another soft key appearing.
    Jon
    May 2006
    214
    Thank you,
    I got it now.
    George
  1. 0TC parameter for more memory?
    By jani in forum Fanuc
    Last Post: 01-16-2010, 11:44 PM
  2. Fanuc OT parameter(s)
    By erwin1958 in forum Daewoo/Doosan
    Last Post: 03-27-2009, 04:36 AM
  3. parameter fanuc om-d
    By dlmusinage in forum Fanuc
    Last Post: 05-17-2006, 10:54 PM
  4. Mazak OP2 parameter
    By xr135 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-17-2006, 08:11 PM
  5. L50 parameter write
    By Bluesman in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2006, 12:49 PM
