603,870 active members*
2,894 visitors online*
Threaded View
    Feb 2015
    5
    Parameters edit -> Mazatrol M32B
    Welcome,
    I'm trying to start milling machine AJV18 with Mazatrol M32b control, which has battery failure.
    I was able to programme parameters of A,B,C,D,E,F,G,H,I,J,K,L,M,N.Q,R,S groups, but I still have problem with some points, which are:
    1) In documentation there is a table called "parameters option" - I don't know where those data should be used.
    It is shown on photo - it's the table in the lower right corner.
    Attachment 267550
    2) In documentation there is also "PLC parameter setting list" which has parameters R2100-R2109,R2110-R2537 (shown on first picture). I know how to get from the option shown on pictures
    but I don't know what to do, to edit those parameters.
    Attachment 267556
    I can't move on if I don't know how to cope with these points. Could you help me and give me some suggestions how to do it?
    With greetings
  1. Mirror image on Mazatrol M32B???
    By jaques4life in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-02-2012, 06:38 PM
  2. Mazatrol m32B Memory
    By sonnentagt in forum EMCO CNC Machines
    Last Post: 06-02-2011, 10:01 PM
  3. need cable wiring PC to Mazatrol M32B
    By chippah in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-10-2008, 02:40 AM
  4. Mazatrol M32B DNC option
    Last Post: 02-01-2008, 09:57 PM
  5. Mazatrol M32B and EMC2
    By iwebcodms in forum LinuxCNC (formerly EMC2)
    Last Post: 11-16-2007, 03:09 AM
