587,326 active members*
2,827 visitors online*
Results 1 to 4 of 4
    Sep 2011
    474
    Path Pilot servo spindle
    Can Path Pilot support a servo spindle for rigid tapping, indexing, more speed + power? Would it need to be a +/-10V driver or could it behave as an extra step/dir axis?
    Aug 2007
    701
    Yes it can. My novakon servo spindle is running PP. it requires some tweaking for sure. But it does rigid tap. I haven't had a need for indexing but it can do all that with some tweaks to the Hal file.
    Sep 2011
    474
    Re: Path Pilot servo spindle
    Quote Originally Posted by brianbonedoc View Post
    Nice. I have some large DC servos that would be perfect. I also have some nema 34 brushless servos that put out 3 times more power and more than double the speed of the current 3ph motor. What kind of tweaks does it require?
    Aug 2007
    701
    Swamp - I have a bunch of posts on this - mostly in the Novakon forum. Basically you will have to look at my hal file and try to adjust it to your system. I will try to help you however I can. I would start with the hardware, mechanicals, and then work on the software side. It's all doable but will not be done in a simple afternoon. Expect to spend a week or so going back and forth.
    Here are my current Hal and ini files for my novakon pulsar. This uses a different breakout board than the tormach, but focus on the spindle section as my driver is a maxsine ep1 with a 1.5kw servo spindle.
    Start to look at the difference between mine and the tormach.
    Attached Files Attached Files
  1. Spindle speed calibration with Path Pilot ??
    By hall6ppc in forum Tormach PathPilot™
    Last Post: 04-16-2017, 04:58 PM
  2. Got my Path Pilot
    By BIG IGG in forum Tormach PathPilot™
    Last Post: 02-10-2016, 03:06 PM
  3. Path Pilot in VM VirtualBox
    By adamvs in forum Tormach PathPilot™
    Last Post: 01-18-2016, 05:43 AM
  4. Path Pilot vs Mach 3
    By Bob La Londe in forum Tormach Personal CNC Mill
    Last Post: 10-12-2015, 07:55 PM
  5. --Unlocking Path Pilot--
    By Jim Anderson in forum Tormach PathPilot™
    Last Post: 09-19-2015, 04:32 PM
