587,118 active members*
2,838 visitors online*
Results 1 to 7 of 7
    May 2008
    57
    PC to Fanuc File Transfer
    I'm trying to transfer my NC program from GibbsCAM to the 0i Mate-MB control. I have a null modem cable and have set the parameters on the control and the PC as listed on this webpage I found.
    http://kfasllc.com/rs232_0.htm
    I've read the Fanuc manual several times and nowhere can I find any procedure for file transfer via RS232. I feel like the manuals are full of information which I can't/won't use; like trying to find the 6V battery which doesn't exist.
    Can anyone tell me the proper procedure (what buttons to press) to prepare the control to receive the file? I think I need to be in EDIT mode and then hit the PROG key but I get lost after that.
    Randy
    SV-2412, 0i Mate-MB
    May 2009
    181
    it doesnt work because you are using parameters for a 0 control not a Oi.
    go to offset setting button..
    make i/o =0
    tv check off
    punch code=1 (for ISO)
    make pwe 1
    go to system, parameters
    make 101 10000001
    103 10 for 4800 baud
    11 for 9600 baud
    May 2008
    57
    File Transfer Successful
    fanucman,
    Thanks for the parameter information. The file transfer work fine now. I did have to change to a straight through serial cable though. The null modem cable would not work properly.
    Randy
    SV-2412, 0i Mate-MB
    May 2009
    181
    Quote Originally Posted by rbcmetalwork View Post
    fanucman,
    you will need a null modem adapter.. a strait through cable WILL NOT WORK with out one..
    call fanuc they can send you a pin out if you want to make your own..
    May 2008
    57
    By straight through cable, I meant that I made a cable with the pinouts as shown in the attached picture (DB25 to DB9). With this cable I successfully transferred a few programs which ran fine with no problems. Am I missing something? I'd hate to screw something up.
    Randy
    SV-2412, 0i Mate-MB
    May 2009
    181
    i thought you meant straight through w/o pins jumped...
    Feb 2008
    10
    I have a .pdf for all the controls with cable digram and RS232 STEP BY STEP procedure to connect a pc to cnc or vice versa.
    write to me at [email protected]
  1. PC to Fanuc File Transfer
    By rbcmetalwork in forum Sharp CNC
    Last Post: 11-05-2009, 08:32 AM
  2. Replies: 4
    Last Post: 10-18-2009, 09:56 PM
  3. Replies: 8
    Last Post: 06-03-2009, 02:14 PM
  4. file transfer
    By axis overtravel in forum Fadal
    Last Post: 01-27-2006, 04:55 AM
  5. EIA file transfer
    By grunemh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-02-2005, 02:45 PM
