Hello guys, please, i have to replicate the clamping from a classical lathe, where the chuck is tightened by hand, part is tapped gentle to adjust the runnout near the chuck, and the steady rest is adjusted so to adjust the runnout at the far end
I have to put this setup on a LB3000ex2 + steadyrest
hydraulic chuck is too strong, so i thought of installing a clasic chuck on the cnc, and in this way i should achieve same setup as on a clasical lathe
i hope i will be able to mess with the senzors, so to make it spin ( i will check this next week )
Any thoughts pls ? Is there a way to make things faster, but at least with same stability as on a clasical lathe ? is there a "cnc" approach for this ? kindly
- i mess with this for a while, and i would really apreciate someone's else suggestions
- consider that you have to clamp the pull bar, that one that is located between the hidraulic cilinder and the nut of the chuck; this part is pretty similar to that ( without threads ); thank you![]()
