588,121 active members*
5,296 visitors online*
Results 1 to 6 of 6
    Sep 2003
    28
    Z axis for porter Cable router
    Hi all,
    I am looking for a way to fabricate a way to support a porter cable router so that is extremely rigid. At this time, I don't need a z axis, just a way to support it (clamp/bracket, etc...). But, down the road (month or 2) I would like to be able to adapt this setup for a z axis
    Is there an off-the-shelf part for this? Does anyone have a quick and dirty "how to" on this from a previous post???
    Thanks for the effort on this :-)
    Mar 2003
    2139
    Can you machine aluminum? If no, you could fabricate a clamp or two of sorts from 3/4" MDF. Make a Square, cut it in half, cut out the two half moons, drill thru both halves for bolts and bolt it to the surface for the z axis.
    Eric
    I wish it wouldn't crash.
    Mar 2003
    106
    Like Balsaman said only I would bore my hole in the center of the block and drill the holes thru for mounting before splitting the block in half. This will assure better alignment.
    Sep 2003
    28
    Thanks for the response guys...does anyone out there have some pics they could post of various "home made" z-axis setups that are extremely sturdy and do not require a machine shop to build.
    Thanks to all who have and do continue to help me out here
    Apr 2003
    1079
    There's a nice wooden one over here
    Mar 2003
    4826
    One other option might be to rebuild the lower motor housing (endbell) out of aluminum, with extra material on one side of it which will permit you to make a bolt on mount. This would be the hard way to do it, but if you want to ensure some kind of permanent perpendicularity, this would be a way to do it.
    First you get good, then you get fast. Then grouchiness sets in.
  1. 3 axis CNC Router with AC/DC Brushless motors (Need help with electronic Design)
    By StressedMech in forum CNC Machine Related Electronics
    Last Post: 05-15-2005, 05:26 PM
  2. Porter Cable Router Motor Mount
    By dowling177 in forum DIY CNC Router Table Machines
    Last Post: 04-05-2005, 01:40 AM
  3. Round 2 :Z axis for porter Cable router
    By camfambmw5 in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2003, 06:14 PM
  4. Mounting a porter cable router
    By camfambmw5 in forum DIY CNC Router Table Machines
    Last Post: 09-28-2003, 02:38 PM
  5. 5 Axis Rotery Head Home Cnc Router
    By mace in forum DIY CNC Router Table Machines
    Last Post: 09-18-2003, 05:29 PM
