603,942 active members*
4,117 visitors online*
Results 1 to 5 of 5
    Oct 2003
    127
    Position Record ...Bad
    When TurboCNC starts. The last line after loading TurboCNC.ini
    tells me that my position record in turboCNC.ini is bad.
    Can I safely delte this file? And have Turbo make a new one?
    Neil
    May 2003
    109
    Yes, But you will loose your settings, including axis and steeper setup.
    Oct 2003
    127
    DID it anyway
    I deleted TurboCNC anyway. I new already what my controller card had as settings for DIR/STEP/HIG/LOW.
    More than anything I wanted the darned thing to reposition correctly. I created a new file. and am alot closer to being an track. At least TurboCNC seems to now where 0,0,0 is now.
    Neil
    Aug 2003
    112
    I've had this a few times too. It seems to happen everytime you forget closing the Turbocnc program first, before shutting down the PC.
    John
    Oct 2003
    127
    That's exactly what I did, Got really frustrated and turned the darned thing off.
    Neil
    Neil Jackson
    HAPPY NEW YEAR
  1. CNC lathe tool and work offsets
    By mm4039 in forum MetalWork Discussion
    Last Post: 11-18-2013, 06:28 PM
  2. Travel distance is inaccurate.
    By thuffner3 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-15-2004, 03:32 PM
  3. How does a servo hold its position?
    By ynneb in forum CNC Machine Related Electronics
    Last Post: 03-08-2004, 04:10 PM
  4. Position record fixed, but more ????
    Last Post: 02-08-2004, 03:24 PM
