603,963 active members*
1,775 visitors online*
IndustryArena Forum > CAM Software > UG NX > Problem in Machine Tool Builder
    Jul 2014
    46
    Question Problem in Machine Tool Builder
    Hello
    I have a problem using the "Machine Tool Builder".
    Steps I did:
    1. First of all, this is my 2axis Lathe Machine(XZ). I have defined 6 tool holders in 2 customs turrets. (picture 1)
    2. In another part, I have machined a piece with a lathe tool with the following properties:
    Tool Number = 5
    Adjust register = 5
    Customs Register = 5
    insert position = Underside
    Holder Hand = Right
    Holder Style = L-Style
    3. When I "Verify Tool Path" the program, it is correct according to the machining image. (picture 2)
    4. When I select and import the machine from the library, tool number T5 does not fit in correct place. (picture 3)
    5. I transfer the position of the tool from T1 to T5 and again run the "Verify Tool Path", and everythig seem OK. (picture 4)
    6. Finally, when I select and run it in the "Simulate Machine",(Rough_TURN_OD_OK operation), the toolpaths move to the positive side of X. (picture 5)
    Please help me with this.
    Thank you very much
    Jun 2025
    18
    Re: Problem in Machine Tool Builder
    you want good quality postprocessors and at a good price. we have a large number of posts www.CADCAMService.pl
  1. Need a custom machine builder
    By ProPixelMedia in forum Want To Buy...Need help!
    Last Post: 12-07-2016, 01:54 AM
  2. looking for custom machine builder
    By BIMP in forum Want To Buy...Need help!
    Last Post: 05-19-2016, 07:13 PM
  3. Job available: Machine Builder
    By Mr. G in forum Employment Opportunity
    Last Post: 09-23-2015, 07:35 PM
  4. Machine Tool Builder Macros??????????
    By Rhemenwa in forum Uncategorised MetalWorking Machines
    Last Post: 04-16-2012, 05:23 PM
  5. Tool Maker/ injection mold builder needed!
    By MnotLyon in forum Employment Opportunity
    Last Post: 03-08-2007, 08:57 PM
