603,988 active members*
3,220 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Problem Upgrading to madCAD 6.0
Results 1 to 6 of 6
    I have just downloaded and installed this ,to run on RH6, but I keep on getting failed initialization message. When I try to double click "madCAD6.rhp" it opens RH5 not 6 ??. I have tried to open with RH6 but keeps on opening in RH5. very confused. Please help.
    Re: Problem Upgrading to madCAD 6.0
    Okay...finally got it to sorta load, but now getting this
    Apr 2015
    5
    I have a similar problem trying to install madCam 6 Release 2018-06-28. I get the same messages when trying to load the plugin.
    Thanks, John
    Feb 2006
    183
    It will not work well to install the madCAM.rhp directly from Rhino. Just run the madCAM installer exe-file.
    1) Make sure that Rhino 6 is closed.
    2) Run the madCAM installer.
    3) Start Rhino 6 and madCAM should automatically load into Rhino 6.
    /Joakim
    Apr 2015
    5
    Hi Joakim,
    I installed madCAM as you stated. The problem occurs in step 3 when Rhino tries to automatically load the plugin.
    I've also tried uninstalling madCAM (with the system "Settings->Apps & features" dialog) and reinstalling--same result.
    John
    Apr 2015
    5
    The latest release (2018-07-02) seems to have fixed my installation problem.
    John
  1. 80 lpm air - upgrading to 450 lpm air
    By KenR60 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-14-2016, 09:28 AM
  2. Who is upgrading to V27 and why?
    By Big Chips in forum BobCad-Cam
    Last Post: 10-17-2014, 04:19 AM
  3. Problem after upgrading to SR 8
    By Andrewlxlxl in forum MadCAM
    Last Post: 06-10-2014, 08:51 PM
  4. Upgrading
    By Captn_tyler in forum Smithy
    Last Post: 06-06-2009, 08:50 PM
  5. Upgrading from X to X3
    By tumchie in forum Mastercam
    Last Post: 01-03-2009, 10:50 PM
