For some time now the motor on my 13x40 lathe has Ben vibrating when turning under power.
An associate suggested replacing the capacitors, as one could be leaking?
So I dug through the Chinese manual for specifics, and found the suggested values of:
460VAC 20MF and 265VAC 150MF
After a trip to Granger, they could only match one exactly.
440VAC 20MF and 330VAC 130-158MF
After a little surgery, (gutting an access hole in the wall) I was able to splice connect longer leads to the newer capacitors. Unfortunately, the lathe's motor still hums and vibrates when powered up!
Is a new motor in order?
Widit
