603,316 active members*
2,117 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Larken > Problems- Artcam Pro to starcam has Larken nc export
Results 1 to 5 of 5
    Jul 2008
    9
    Unhappy Problems- Artcam Pro to starcam has Larken nc export
    has Larken_in *.nc toolpath creation does not work properly says i???
    need help with Artcam to print on my Larken 50
    cannot import it to starcam what other methods are availabe in starcam/artcam
    please help... also have profilelab 3d this works well with starcam so if there was a way to put artcam file to profilelab the to starcam i'd be happy with that>?
    Jul 2008
    9
    Smile solution
    i found to export as gcode .tap in Artcam and rename it .nc and import gcode command in starcam works well!!! found a solution should post it on your website!!!
    Jul 2008
    9
    help
    actually Larken program fully supports .tap as an output???? because i am having problems with starcam 1.91
    Jul 2008
    9
    help more info
    see attached for file how do you open it???? starcam displays nothing when renamed to .nc
    Attached Files Attached Files
    Feb 2007
    972
    Good, you figured it out. The tap file is a gcode, just with a different extension.
    I'm planning to have an updated chip for the starcam board by the fall, that will add a bunch of features.
    I will post in this forum when its ready.
    Larry K
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
  1. Upgrading from Lcam to StarCam
    By Larken in forum Larken
    Last Post: 06-05-2011, 04:35 AM
  2. Export 3DSMAX files to ARTCAM PRO
    By fspl in forum ArtCam Pro
    Last Post: 12-03-2008, 08:58 AM
  3. How do I export my artcam stuff to my cnc machine
    By thegimpster in forum ArtCam Pro
    Last Post: 08-05-2008, 10:09 AM
