603,870 active members*
3,178 visitors online*
    May 2009
    Problems whit angular head
    Hi I am new to the forum here
    We have purchased a new machine FRAL400 a milling machine, that we have problem with the angle head..
    Control we use is simens840D
    and we use Mastercam X3
    I have an X-axis 22000MM on the y-axis 5000MM
    We have a problem with our angle head, angle head has a C axis that rotates
    360 degrees, when we work in the 0 degrees stays the milling head vertical down,Then we can use this
    program to mill the contour
    N10 LOAD_TABR
    N20 T="390125FRES"
    N30 L06
    N40 G17 G54 G64 G90
    N50 Z1700
    N50 TOOL_HOLDER(0,0)
    N60 TOROT
    N70 G54
    N80 F5000
    N90 S500 M03
    N100 G0 Z1925
    N110 G0 Y60.5 X-80.208
    N120 G0 Z1720
    N130 G1 Z1700
    N140 G1 X-42.708
    N150 G1 X372.5
    N160 G1 Y-60.5
    N170 G1 X-42.708
    N180 G1 X-80.208
    N190 G0 Z1925
    N200 M5
    N210 ROT
    N220 M0
    but when we turn our head 45 degrees, we must replace the x axis with the y axis
    so then we must create new programs to the next angle
    though the contour is the same
    then we have to program like this
    N230 TOOL_HOLDER(45,0)
    N240 TOROT
    N250 G54
    N260 F1000
    N270 S500 M03
    N280 G0 Z1925
    N290 G0 X60.5 Y-80.208
    N300 S500 M03
    N310 G0 Z1720
    N320 G1 Z1700
    N330 G1 Y-42.708
    N340 G1 Y372.5
    N350 G1 X-60.5
    N360 G1 Y-42.708
    N370 G1 Y-80.208
    N380 G0 Z1925
    N390 G0 Y-200
    N400 ROT
    N410 M5
    but when we post out, the mastercam X3 using the same contour on all axes
    like this
    N10 LOAD_TABR
    N20 T="390125FRES"
    N30 L06
    N40 G17 G54 G64 G90
    N50 Z1700
    N60 TOROT
    N70 G54
    N80 F5000
    N90 S500 M03
    N100 G0 Z1925
    N110 G0 X60.5 Y-80.208
    N120 G0 Z1720
    N130 G1 Z1700
    N140 G1 Y-42.708
    N150 G1 Y372.5
    N160 G1 X-60.5
    N170 G1 Y-42.708
    N180 G1 Y-80.208
    N190 G0 Z1925
    N200 M5
    N210 ROT
    N220 M0
    N240 TOROT
    N250 G54
    N260 F5000
    N270 S500 M03
    N280 G0 Z1925
    N300 G0 Z1720
    N310 G1 Z1700
    N320 G1 Y-42.708
    N330 G1 Y372.5
    N340 G1 X-60.5
    N350 G1 Y-42.708
    N360 G1 Y-80.208
    N370 G0 Z1925
    N380 M5
    N390 ROT
    N400 M0
    N410 M2
    CONTOUR
    GEARBOX
    Does anyone have experience with an angle head,
    or been in the same situation that can help me with this ?
    Thanks for all posts
    Jul 2003
    1220
    I have a manual universal head on a 3 axis mill with a Fagor controller.
    To do a job like yours, I would change the plane. (Fagor G49 C45) and use the same code for each face.
  1. Problems whit feeds and Speeds
    By jensen in forum BobCad-Cam
    Last Post: 10-18-2008, 05:09 AM
  2. Problems with tapping head.
    By Chuck Reamer in forum Tormach Personal CNC Mill
    Last Post: 11-12-2007, 04:16 PM
  3. job setup -round whit a hole
    By osomaker in forum Mastercam
    Last Post: 12-21-2006, 03:51 PM
  4. Quill and head problems?
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 11-24-2006, 03:32 PM
  5. Help whit ini Metric
    By essa in forum LinuxCNC (formerly EMC2)
    Last Post: 04-13-2006, 08:19 PM
