HI guys,
I have been building a homemade mill and it is going well. I have been testing with MACH3 and loving it. I do have a question though:
How do I make sure that my axis travel the distance that the DRO says? In other words, when my DRO travels 2 inches even, the axis actually travels like 1" 7/8.... I have been trying to play with the settings in "motor tuning" where you can tell MACH3 the distance that the axis travel with 1 revolution of the motor...problem is... it's practically impossible to tell precisely when the motor finishes its revolution. Of course I can eyeball it but it won't be accurate. Is there a way to make the motor rotate a precise 360 degrees so I can calculate the distance the axis travels? Or, perhaps there is another accurate way to dial that in .. Any thoughts?
thank you
MAX
