ikahn42:
I think your statement is correct for the most part. Using a ball screw or an ACME screw with some type of backlash adjustment system for the Z Axis is a good idea in most cases.
I think what needs to be cleared up is that my previous posts were regarding rack and pinion versus leadscrew systems used in all axes. If I were to design a new Z Axis I would almost certainly use a leadscrew setup because it would be the easiest to implement for that purpose, but I don't believe that a rack and pinion is necessarily a BAD idea on short spans either, at least in terms of performance. A rack and pinion will have the same performance characteristics on a short span as it would on a long span since all that is turning is the pinion in either case. A ball screw or other leadscrew is different, however, since the longer the span, the larger the rotating weight. Z Axes are typically fairly short and the mechanical advantage of leadscrews, compared to rack and pinion systems, is usually a benefit for the Z Axis. There are obviously going to be pros and cons of both systems in terms of installation, but that depends on the overall design.
When considering different options for the design of your system it all depends on how everything will work TOGETHER. It also depends on what you are trying to accomplish in terms of the type of material (steel versus wood or plastic) you are cutting, the method of cutting (plasma, router, laser, etc), and the performance you are seeking.
If anyone ever tells you a certain method of doing something is "bad" or "wrong", then their advice should be evaluated carefully. What is wrong for one application may be just right in another.
My first gantry build was a leadscrew system with ACME screws and plastic anti-backlash nuts. My latest build was using a rack and pinion. You can see the rack and pinion gantry here:
YouTube - cjamasterworks's Channel
