603,884 active members*
4,783 visitors online*
Thread: RC unit
Results 1 to 6 of 6
    Apr 2010
    486
    RC unit
    Trying to salvage a few of the mechanical relays from the Bridgeport under rehap.
    No problem, pretty straightforward.
    But have noticed that almost every relay has a component between the first of the common points and the first NO points.
    It's marked:
    RC Unit
    630 vdc, 250 vdc (or thereabouts)
    .1 mfd 100 ohms
    Looks like two separate components with amber colored epoxy or similar cast around them.
    Any idea why these were there?
    Tom
    Dec 2003
    24260
    Are you sure it is not across the coils, snubbers are used on AC circuits to quench back emf or spikes that may occur when the coil releases, the DC equivalent is the reverse EMF diode across the coil.
    Al.
    Albert E.
    Sep 2010
    1765
    Al, I've seen some designs where the rc networks were put across the contacts also to try to mitigate the sparking on opening an inductive load.
    Apr 2010
    486
    Quote Originally Posted by Al_The_Man View Post
    Al.
    Yeah, Al, I was expecting them to be across the coil, and was surprised when they were not across the coil.
    Most of relays are 11 pin tube socket type. Pins 2 and 10 are always (on these, at least) the coil, and the snubbers are connected from pin 1 to pin 3.
    And by the way, mine look exactly like the picture you posted.
    Tom
    Dec 2003
    24260
    Iv'e found them fitted to contacts on rare occasions, but usually the relay has been under rated and the 'fix' is to add a snubber instead of using the correct size contacts.
    If the contacts are switching a high energy DC inductive load, you can get relays fitted with magnetic arc-blowout feature, this is a magnet adjacent to the contacts.
    Al.
    Albert E.
    Sep 2010
    1765
    or an engineer who added snubber across the contacts instead of the proper design of adding a diode across the dc inductive load itself to supply path for the inductive voltage spike....
  1. Configuring steps/unit.....what unit?
    By HereinCS in forum Mach Software (ArtSoft software)
    Last Post: 03-08-2011, 02:57 AM
  2. UPS unit
    By Power Supply in forum News Announcements
    Last Post: 10-11-2010, 10:22 AM
  3. FANUC 15-MA Battery unit & I/O unit etc
    By gbowne1 in forum Fanuc
    Last Post: 05-05-2010, 02:47 AM
  4. Unit Problems
    By skipper in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-14-2009, 11:08 PM
  5. I/O unit
    By guhl in forum Fanuc
    Last Post: 08-20-2007, 07:32 AM
