Hi there,
We have a job of small parts out of .060 acrylic that we currently do on a small cnc router. Very time consuming as we have to double mask the bottom and not cut right thru so we can maintain vacuum hold down. It is do able on our laser other than in the start and end of a line, it cuts thru still when our setting is perfect for the rest. The split second time that the laser is in one spot at the start and end of a line or in a corner, is long enough to burn thru. In our software or any tricks to have a lead in and lead out to avoid the problem??? Thanks in advance.
Jeff
