587,255 active members*
3,001 visitors online*
Results 1 to 5 of 5
    Jul 2004
    240
    Reading KStep board bits? How to??
    Greetings,
    I am trying to read the KStep Bits, I do see them in the KMotion Digital I/O Screen:
    //GV.in0 = MainStatus.GetKFlopBitState(0); //Changed to Read KStep Board Inputs.
    GV.in0 = MainStatus.GetVirtualBits(168);
    //GV.in1 = MainStatus.GetKFlopBitState(1);
    GV.in1 = MainStatus.GetVirtualBits(169);
    //GV.in2 = 0; //MainStatus.GetKFlopBitState(2);
    GV.in2 = MainStatus.GetVirtualBits(170);
    //GV.in3 = 0; //MainStatus.GetKFlopBitState(3);
    GV.in3 = MainStatus.GetVirtualBits(171);
    Is the KStep bits considered KFlop bits??
    Thanks,
    - Jeff
    Robot & Machine Design - BLUECNC4, GreenCNC3, RedCNC2L, SilverCNC2; CNC Software!
    www.truemachinedesign.com - - - - - - - - - - - - - www.truemachineautomation.com
    May 2006
    4047
    Re: Reading KStep board bits? How to??
    Hi Jeff,
    The 16 KStep Inputs are multiplexed into KFLOP using 4 KFLOP Inputs. To enable the multiplexing the flag:
    KStepPresent=TRUE; // enable KSTEP input multiplexing
    needs to be set. See the description here under Digital Status:
    Using KStep
    Are you doing this?
    HTH
    Regards
    TK
    http://dynomotion.com
    Jul 2004
    240
    Quote Originally Posted by TomKerekes View Post
    Hi Jeff,
    Using KStep
    Are you doing this?
    HTH
    Regards
    YES... I do see them... and use in homing... how do I access
    there status in my C# .net program...?
    May 2006
    4047
    Hi Jeff,
    Ahh, the 16 KStep Inputs are Virtual Bits packed into the high 16 bits of the MainStatus VirtualBits word. They would be accessed from .NET with MainStatus.GetVirtualBits(16) ... MainStatus.GetVirtualBits(31).
    HTH
    Regards
    TK
    Jul 2004
    240
    Ok,
    GV.in1 = MainStatus.GetVirtualBits(16); //This is KStep Board bit 168
    GV.in2 = MainStatus.GetVirtualBits(17); //This is KStep Board bit 169
    and so forth...
    GV.in1 is my C# integer where I track my inputs.
    No where could I find documentation, that told me how to access the KStep board bits...
    Thus this thread.
    __________________________________________________ ______
    Thanks so much for your help, now I got it working....
    - Jeff R.
  1. Smoothieboard, new opensource, ARM 32 bits ( Cortex-M3 ) CNC controller board
    By arthurwolf in forum Open Source Controller Boards
    Last Post: 05-23-2017, 05:24 AM
  2. Replies: 6
    Last Post: 08-21-2015, 07:24 PM
  3. KStep Motor 0
    By sdavenport in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-14-2015, 05:24 PM
  4. Kflop+kstep out of syn
    By ltran2000 in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-09-2012, 04:41 AM
  5. Reading 12 bits // encoder - Lead & Lag
    By dehclau in forum CNC Machine Related Electronics
    Last Post: 10-27-2004, 08:03 AM
