603,965 active members*
2,529 visitors online*
Results 1 to 5 of 5
    Oct 2006
    Thumbs up Record 110 and Xilog Plus
    We have a record 110 which I am responsible for programing and am getting on great I just have on thing that occasionally catches me out, imagine trying to cut a squre hole in a piece of timber where the off cut is to small to catch so I would tend to make a number of passes producing sawdust until the hole is the required size. Now all works well until the tool diamete chages as a resharpen this obvioulsy affects how much i can remove on each pass.
    Now the question is it possible to retrieve the diameter for the tool currently loaded into the spindle under xilog plus ? This would solve my problem,
    Thanks in hope
    JD
    Feb 2007
    yea you can mate.
    theres a whole load of information you can call up about your tools,
    on my record 100al, id use the following:
    L VARNAME =(TOOL(102, 10))
    that sets a variable called varname which has the diameter of tool 102
    hope that helps.
    tom
    Nov 2011
    The way we do it, is machine the square hole as a pocket. After a regrind measure the diameter and input those details into your tool file, usually it is a def file, then fixed tools. Hope taht helps.
    Jul 2008
    20
    you have to measure the tool diameter & enter it into your tool file so whats the problem
    May 2006
    42
    Make sure to leave some stock there and make a final pass using tool comp. C=1 or C=2. Pocketing does not use tool comp.
  1. SCM Record 121
    By craigy85 in forum Commercial CNC Wood Routers
    Last Post: 03-08-2008, 11:38 PM
  2. Licom To Xilog Plus
    By mnchaos in forum CNC Machining Centers
    Last Post: 07-09-2007, 04:10 PM
  3. surface machining + xilog
    By Shawnm in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-18-2006, 02:55 AM
  4. Position Record ...Bad
    By thuffner3 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2004, 12:16 PM
