587,216 active members*
2,680 visitors online*
Results 1 to 6 of 6
    Jan 2004
    668
    Recurring Issue
    I have this issue that keeps popping up every so often. I have a Mini Mill built from LittleMachineShop parts, which usually runs smooth and true. But then the, " x" axis bearing comes lose, as to chatter under less than medium hand speed loads. I have re tightened it about twenty time or more only to have it go wonky again. Any ideas as to how I can simply correct this issue.
    Jul 2005
    969
    did you use some locktite on the screw that holds the bearing
    The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
    Jan 2004
    668
    That's a fabulous idea. Seriously I didn't even think of that, thanks.
    Jul 2005
    969
    no problem, glad i help
    Feb 2007
    632
    Try to add another nut to the end if you still have enough screw end. You can tightened the outer nut to secure the x axis bearing in place.
    By doing so, you won't have problem with having to work hard to get the nut out as the locktite may stick so well. Just a thought.
    Dec 2004
    1865
    Quote Originally Posted by ataxy View Post
    Use the blue low/medium loctite as the red high strength will require heat to remove it most of the time.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
  1. recurring problem - no holding torque
    By sunward in forum Gecko Drives
    Last Post: 08-28-2008, 12:25 PM
  2. TM1 Monitor issue
    By f1jdm in forum Haas Mills
    Last Post: 01-21-2008, 05:44 PM
  3. Repeating issue
    By scorchtool in forum Milltronics
    Last Post: 01-19-2008, 02:26 PM
  4. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
  5. THC Issue
    By Aldoseri in forum CamSoft Products
    Last Post: 01-31-2006, 11:33 AM
