603,348 active members*
3,149 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > recurring problem - no holding torque
Page 1 of 3 123
Results 1 to 20 of 51
    May 2005
    22
    This problem I have has been going on for some time and I am at the point of throwing everything out and starting fresh with products (industrial, generally not for sale here). Everyone seems to say it is something else is causing the problem.
    I am posting here as the unit showing a fault is the Gecko drive.
    First, everyone I contacted has provided help.
    I have a CNC lathe running under Turbo cnc. After about 30 minutes, one drive loses holding torque. If I reset the Gecko drive (one of the pins), the holding torque comes back. If I turn the power off to the drive/motor, I can use the system again after about 20 to 30 minutes. Will go through the same problem.
    I have both drives running under G212. I have used 3 different drives on the axis and the same problem occurs.
    I have a Keling NEMA34 SINGLE SHAFT STEPPER MOTOR 400 oz-in and an 1160 oz one on the problem axis. 4.2A/ phase.
    Power supply is a 65 VDC 6ADC from Transformer Technology. I contacted them and the power supply should be good.
    I have also changed the computer in use.
    I contacted Gecko drive and the problem was the unit shutting down due to an overload. Suggested I change the motor.
    I installed a 400 oz motor on the problem drive ( dual shaft as out of stock on single shaft).
    The lathe worked like a dream!
    For hours on end with no interruption or lose of holding torque.
    Until this afternoon.
    The same problem returned
    I shut the system down to cool. No effect.
    For the record, I was advised I needed a breakout board. I ordered one from Campbell Designs and was trying to install it but ran into problems. ( seems not easy for Turbocnc use). I did email back and forth with Bob Campbell but had to put this on hold until I had more time.
    ANY suggestions?
    Angelo Castellano
    Sunward Aerospace Group Limited www.sunward1.com
    Apr 2005
    1778
    Have you got heatsinks on the Gecko's?
    Alan
    Mar 2008
    3655
    Formula for maximum motor voltage: Square root of motor inductance, times 32 = max.
    Keling 400 oz N34 = 1.65 MH inductance. Sq. Rt. of 1.65 = 1.28. 1.28 X 32 = 41.
    By my calculation, if these 400 oz motors are wired bipolar parallel, they should be run at no more than 41 volts. Sixty five volts must be overheating them terribly. Once a stepper gets TOO hot, it will lose magnetism and never run again.
    You should only be running these 400 oz motors at 36 volts.
    CR.
    May 2005
    22
    Quote Originally Posted by acondit View Post
    Alan
    They are mounted on an aluminum plate and have not gotten hot up to this point.
    Quote Originally Posted by Crevice Reamer View Post
    ....You should only be running these 400 oz motors at 36 volts...
    Amazing. I ordered the power supply based on the recommendations of the company.
    Sent an email to Keling and waiting for a response.
    Contacted Transformer Technology and they will custom build a 36V 8A system and I will send the current one back. Waiting for a price.
    Angelo Castellano
    Mar 2008
    3655
    The 1160 oz motor wired bipolar parallel could run at 80 V. The 400 oz motor wired in bipolar SERIAL (half the power and speed of B. P.) could run at 82 volts.
    Perhaps you did not understand when Keling explained that the 400s had to be wired bipolar series to function.
    Now you may need another 400 oz motor to replace the one that got cooked. If he did NOT explain to you how this motor had to be wired, then maybe he will replace it for you. The KL320-36 8.8 Amp power supply @ $59 would be adequate for two 6 amp motors if he had them in stock.
    CR.
    May 2005
    22
    The 1160 oz motor wired bipolar parallel could run at 80 V. ..
    The specs for the motors were given to the power supply company and they made the recommendation.
    IIRC, no mention of inductance was made at the time.
    The motors are not fried.
    Angelo Castellano
    Mar 2008
    3655
    Quote Originally Posted by sunward View Post
    Ahhh! So it was the PS company, not Keling. Well they got it HALF right.
    WOW! If those 400 oz. motors have been running at 180% of their normal voltage, AND they are NOT fried--Those Keling motors must be some FANTASTICALLY GOOD MOTORS!
    Glad to hear all will work out, and By the way:
    Welcome to the Zone sunward!
    CR.
    Jan 2007
    467
    Sunward,
    From what I can gather from your first post, you had a 1160 oz motor that was giving you problems and you replaced it with a 400 oz motor and it worked for a little bit. Is that correct? I am just trying to sort it all out in my head so I can figure out exactly what is going on.
    Marcus Freimanis
    May 2005
    22
    Quote Originally Posted by CoAMarcus View Post
    Sunward,
    Marcus Freimanis
    Had a 400 and 1160 oz motor. Having the problem with the 1160oz motor. Replaced that one with another 400 motor. Worked great at first, then the same problem.
    The other axis has never been a problem.
    Angelo Castellano
    Jan 2007
    467
    Sunward,
    Have you tried swapping the motors from each axis, or swapping in a different motor aside from the 400 oz-in to see if the problem stays with the problem motor? I know you have already swapped, but try swapping it with a motor of comparable specs. Also, what is the size of your current set resistor?
    Marcus Freimanis
    Mar 2008
    3655
    Upon re-reading your post, I notice that you were running two 6 amp motors on one 6 amp power supply. Those two motors would require at least 8.4 amps for best performance when both are running at the same time. I don't know if that caused a problem, but it's definitely not efficient.
    CR.
    Jan 2007
    467
    CR.
    That is why I am very interested in his current set resistor size. I fear he may have a current set resistor on both of 4.2A, and with both running at full load they are stalling.
    Marcus
    May 2005
    22
    .... Have you tried swapping the motors from each axis, ... Also, what is the size of your current set resistor?...
    I never tried to switch the motors. Seemed too much work for no reason. ( I did change the drives as stated.)
    300K ohms on each driver. Checked the bands and with a meter.
    Upon re-reading your post, I notice that you were running two 6 amp motors on one 6 amp power supply. Those two motors would require at least 8.4 amps ...
    4.2 A /phase. The power supply was the recommendation of the supplying company. I confirmed this 2 days ago to make sure it wasn't a problem. The rep stated the unit will go as high as 8 A so should be sufficient. The fuse has never blown.
    Angelo Castellano
    Mar 2008
    3655
    4.2 A /phase.
    Amps per phase depends on how the motors are wired:
    1. UNIPOLAR = 4.2 A
    2. BIPOLAR SERIAL =3 A
    3. BIPOLAR PARALLEL (Which is the BEST way to wire them) = 6 A
    http://kelinginc.net/KL34H260-42-8A.pdf
    Which way are your motors wired?
    What Gecko drivers are you using?
    CR.
    May 2005
    22
    ...3. BIPOLAR PARALLEL....6 A.......What Gecko drivers are you using?
    My mistake. Yes 6A on bipolar parallel.
    G212. Common ground.
    Angelo Castellano
    Mar 2003
    35494
    Isn't the common terminal on a G212 5V?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  17. #17
    May 2005
    22
    I was mentioning it as to the jumper setting was for common ground.
    Angelo Castellano
  18. #18
    Apr 2005
    1778
    Ger,
    I looked at the g212 manual, the common is jumper selectable (GND or +5).
    Angelo,
    Have you had any luck figuring out what is/was going on?
    Alan
  19. #19
    May 2005
    22
    ....Have you had any luck figuring out what is/was going on?...
    Transformer Technology has yet to call back. Keling didn't respond to an email request.
    Looks like the power supply supply is the problem. On Monday I will look into just building one and see if this solves the problem. Looks like I found a source for the transformer and the other parts are readily available.
    Angelo Castellano
  20. #20
    May 2005
    22
    Still nothing from Keling (not waiting any longer) and I called Transformer Technology after they didn't call back.
    I was to get a quote today, but never did. Will see.
    I looked into modifying the power supply I now have ( 65V 6A ) but didn't seem to be able to.
    At the same time, I looked into a building a power supply on my own. As per Crevice Reamer and bob Campbell's design, I think the following is what I need:
    From Plitron, a transformer 2 x 18V at 8.33A
    From Electrosonic, a BRIDGE rectifier SQUARE GPP GBPC 35A 50V by Diodes Incorporated
    and a CDE ST ALUM CAP 40V 20000UF 51X143 13.6A from Cornell Dubilier ( Aluminum Electrolytic-Computer Grade/ MALLORY/CDE )
    I had computed 8.04A ( 67% of 2x6) At 36VDC @ 8.04A, I need a 289 VA transformer (above is 300). At 36V and 8.04 A,I need a 17,866uF capacitor. The above are in stock, except for the transformer, about 1-2 weeks. The transformer output would be wired in series.
    Are the computations correct and the parts correct?
    Angelo Castellano
Page 1 of 3 123
  1. How to determine the Holding Torque Requirement?
    By joprinz in forum Stepper Motors / Drives
    Last Post: 11-19-2007, 11:59 AM
  2. No holding torque or movement with G201
    By patdttr225 in forum Gecko Drives
    Last Post: 09-03-2007, 05:16 AM
  3. Holding torque?
    By Marc in forum Servo Motors / Drives
    Last Post: 08-22-2006, 09:19 PM
  4. Holding torque Ncm vs Oz/in
    By Georgie in forum Stepper Motors / Drives
    Last Post: 12-14-2005, 09:58 AM
  5. Holding Torque (please help)
    By dowling177 in forum Stepper Motors / Drives
    Last Post: 01-18-2005, 08:59 PM
