588,099 active members*
5,195 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Reducing noise by using a capacitor.
Results 1 to 5 of 5
    May 2010
    Question Reducing noise by using a capacitor.
    I'm attempting to wire up a Z zero plate and after some discussion on the forum,
    http://www.cnczone.com/forums/diy-cn...ml#post1100345
    It appears that I'm getting to much noise on the pin that I'm using. It was suggested that I use a capacitor to reduce the noise, but I'm not sure how to wire it up, I'm hoping someone on the forum has had this issue, and can help.
    Thanks for the help,
    Apr 2006
    3206
    Since no one else is jumping in here....
    I'm guessing you need a band-pass filter, a simple RC circuit.
    Quote Originally Posted by KnotsAboutWood View Post
    I just fixed my noise problem on the Z zero auto tool set. My problem was that i was mounting my fixed tool setting height fixture on an aluminum table. I isolated the plate from the table and that fixed the probe LED flickering problem. Maybe this will help
    farmertom
    http://cncartwork.weebly.com/index.html
    Jan 2009
    123
    I assume your "zero Plate" device has three terminals (Gnd, Vin and SigOut)? If so put the cap acrosss the gnd and input. This will reduce some noise entering from the power supply.
    Mar 2010
    371
    He found and fixed his problem, but the cap is best placed as close to the input as possible, so at the BoB, not at the plate. Usually, for this kind of problem just a capacitor is all you need, but a series resistor may be needed in serious cases. You could also use a ferrite bead for some kinds of noise.
  1. reducing the size..........
    By Shane1234 in forum Mastercam
    Last Post: 09-19-2011, 05:22 PM
  2. Capacitor value for noise .1 or .01 and why?
    By Fastest1 in forum CNC Machine Related Electronics
    Last Post: 08-16-2010, 05:32 PM
  3. Reducing nodes
    By Traneman in forum Torchmate
    Last Post: 04-21-2010, 09:57 PM
  4. Reducing RF Interference
    By stirling in forum Gecko Drives
    Last Post: 04-09-2010, 04:40 PM
  5. Reducing amperage?
    By stdly in forum CNC Machine Related Electronics
    Last Post: 02-23-2006, 04:23 AM
