I would like to get some quotes on making 20 of these parts. The shape of the parts will require multi-axis machining. The part is 3.375" tall x 2.75" dia with the boss protruding from the side at a 45 degree angle. There are threaded holes on the top, bottom and sides.
Tolerances of +-.005, except for the center bore which needs to be +.002 -.000. No surface treatments necessary. You will need to provide the material.
The part is currently modeled in solidworks, but I can provide CAD model in whatever format you need.
I have an immediate need for the initial order of 20 parts. Based on the success of the initial order, there is potential for additional orders of larger quantities. I would like to limit the RFQ to the USA.
thanks
