603,314 active members*
3,150 visitors online*
IndustryArena Forum: Rhino 3D
Page 2 of 24 123412
Threads 21 to 40 of 477
Discuss Rhino 3D software here.
  1. Solid union
    Started by Melkiades, 04-10-2017 11:21 AM
    04-15-2017, 12:50 PM Go to last post
  2. Question How could I model this?
    Started by enesoz, 03-28-2016 01:25 AM
    01-02-2017, 06:12 PM Go to last post
    12-25-2016, 12:13 PM Go to last post
    12-16-2016, 01:36 PM Go to last post
    12-15-2016, 03:17 PM Go to last post
  3. Boolean operation on STL files
    Started by andre-dolphin, 11-14-2016 05:17 PM
    boolean, file, model, operation, stl
    11-14-2016, 06:43 PM Go to last post
  4. How to close this geometry?
    Started by vodjoa, 11-10-2016 12:37 AM
    11-14-2016, 06:08 PM Go to last post
  5. ArtCAM substitute?
    Started by Arnie, 06-01-2004 04:56 AM
    artcam, bit, cam, copy, environment, evaluation, full, good, guess, hey, hose, ice, its, jewellery, look, modelling, programs, rhino, surfacing, things, thought, tools, understand, users, versa, versatile, ways, website
    10-19-2016, 04:34 PM Go to last post
    10-14-2016, 08:35 PM Go to last post
  6. "T" problem in Rhino text
    Started by popspipes, 01-27-2016 01:56 PM
    function, line, problem, single, text
    10-05-2016, 06:06 AM Go to last post
  7. Question Bread bin from 3 or 6 mm MDF With rolling top
    Started by criekert, 09-30-2016 06:57 PM
    advise, bin, bread, rolling, top
    09-30-2016, 06:57 PM Go to last post
  8. Question 3D laser cut 3mm MDF 4 wheeler quad bike
    Started by criekert, 09-30-2016 06:52 PM
    bike, dxf, file, make, quad
    09-30-2016, 06:52 PM Go to last post
    08-09-2016, 07:24 PM Go to last post
  9. Variables in Rhino?
    Started by RobSm, 02-01-2016 10:54 PM
    data, key, model, read, variables
    04-18-2016, 05:45 PM Go to last post
  10. adding spokes to 3d file
    Started by koisuruusagi, 06-22-2015 06:09 AM
    04-18-2016, 10:44 AM Go to last post
  11. machining operations in Rhino
    Started by RobSm, 03-01-2016 01:57 AM
    exported, fret, operation, slots, time
    03-05-2016, 01:34 AM Go to last post
  12. using layers
    Started by RobSm, 12-22-2015 07:47 AM
    bits, layer, machine, question, rhino
    01-31-2016, 08:29 PM Go to last post
  13. polysrfaces won't join.
    Started by RobSm, 01-22-2016 05:10 AM
    01-31-2016, 07:10 PM Go to last post
  14. Planar curves
    Started by popspipes, 01-13-2016 07:44 PM
    boolean, causing, curves, planar, problem
    01-15-2016, 01:16 AM Go to last post
    01-07-2016, 11:15 PM Go to last post
Page 2 of 24 123412
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
