588,058 active members*
5,198 visitors online*
IndustryArena Forum > CAM Software > Mastercam > rotating a large arc or spline to tangent on 2 arcs
Results 1 to 5 of 5
    Jul 2010
    117
    I have a large arc or spline 40 inches long. I have the spline setting tangent on the left dowel. I want to rotate the arc/spline keeping it tangent to the left to where it is touching the tangent of the right pin. Pins are app 25 inches apart. Pins have to stay stationary on the tool as there are 7 different parts with different radiuses being located on the dowels how is the best way to rotate the part to touch tangent on both dowels. Im using X5 is there an easier way to do this than drawing a line tangent to the arc/spline to center of right pin then trim to edge of pin snap to lines and rotate the angle of the 2 lines using the center of the left pin as the axis. doing this several times until you get it within .0005
    BE NICE TO THE NERDS IN SCHOOL. THEY ONE DAY MAY BE YOUR BOSS
    Dec 2008
    3136
    - Just thinking out loud !! ( dangerous, I know )
    - offset the spline/arc by the radius of the pins
    - create a 25" circle to bisect the new geometry
    - Xform 3D the "paired" geometry so the new geometry intersection points go thru the pin centers
    - delete new geometry and 25" circle
    Jul 2010
    117
    here is an image of what I am wanting to do The left pin is tangent to the arc I want to rotate the large arc to tangent with right pin while maintaining tangent with left pin
    Dec 2008
    3136
    to throw in a similar step
    - translate your arc ( plus offset geometry ) from L/H instersection of 25" circle & offset geometry to L/H pin center
    - analyse the angle "3 points" from R/H pin center, L/H pin center, R/H intersection of 25" circle & offset geometry
    - take that 1st angle value and then Xform rotate ( around the L/H pin center ) the previous translated geometry - you may have to reverse the rotation direction --- you have just placed the offset geometry thru the pin centers, which makes the old geometry tangent
    Jul 2003
    1220
    I don't know MC but I would draw two arcs with a radius of the spline radius less the pin radius using the pin centres.
    Then draw another arc with the spline radius, using the intersect point.
  1. software to convert spline curve to tangent arcs
    By foxfx in forum Uncategorised CAD Discussion
    Last Post: 05-08-2014, 02:31 PM
  2. Replies: 5
    Last Post: 09-09-2009, 01:58 PM
  3. Tangent Arcs Mastercam 9.1
    By taa1967sma in forum Mastercam
    Last Post: 03-23-2009, 08:47 PM
  4. Tangent lines joining two arcs
    By yongchiprsnapr in forum Mastercam
    Last Post: 11-30-2008, 11:39 PM
