588,556 active members*
4,959 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Rotating part along the z-axis
Results 1 to 9 of 9
    Mar 2009
    10
    Seems like a simple enough task but I can't figure it out.
    My parts face is on the z and x axis and i need to get it to the x and y.
    Oct 2006
    23
    Are you talking about milling on a lathe? with your C axis?
    This site changed my life ----> www.alittlebiteasier.net
    Mar 2009
    10
    No just a gantry router.
    Dec 2008
    3142
    I'll describe a method of moving the part
    ---if you want the method of creating a WCS, let us know---
    If you want the RIGHT side of the part to be rotated to the TOP, it would have to be rotated, as you would look at it from the FRONT. ( OK so far ? )
    To be able to rotate "around the Y axis", the C-plane (construction) must first be set to the FRONT plane
    Method
    - turn all levels on
    - select C-plane=FRONT
    - select all entities
    - Xform-rotate and accept ( big green dot )
    - popup dialogue appears ( input angle of +90 degrees ), the multi-direction arrow is for selecting the rotation point if different from the origin.
    - accept
    Gview TOP
    The RH side of the part is now at the TOP
    ---don't forget to put C-plane back to top---
    now Xform-translate to correct position
    Aid assistant- try turning on, an inactive grid to be always visible to show C-plane and construction Z level
    - alt-G ( grid dialog display )
    - active grid=off
    - visable grid=on
    - spacing X.25 Y.25
    - color 8
    - size=1.5"
    Oct 2006
    23
    sounds like you need to draw it from the top side view
    Mar 2009
    10
    Quote Originally Posted by Superman View Post
    Method
    - accept
    Gview TOP
    - active grid=off
    - visable grid=on
    - spacing X.25 Y.25
    - color 8
    - size=1.5"
    Thanks So much for your help I'll have to do this tomorrow. Your a life saver
    Dec 2008
    3142
    The spammer is Go.oo...ne
    Mar 2009
    10
    Is my questions obnoxious (spamish)?
    Sorry I didn't mean to be a bother.
    Dec 2008
    3142
    Sorry guys
    We had a spammer going troppo thru the forum yesterday, he was reported and all trace was deleted , yes he dropped a bit in here
  1. Rotating NC program in over Y Axis
    By yaji63 in forum MetalWork Discussion
    Last Post: 12-26-2008, 05:21 AM
  2. Foam Cutting Rotating Axis
    By professionalcnc in forum Italian
    Last Post: 10-30-2008, 07:38 PM
  3. Rotating axis addition - Questions about lathe chucks.
    By tahustvedt in forum DIY CNC Router Table Machines
    Last Post: 03-06-2008, 07:25 PM
  4. Rotating Nut Ball Screw for dual X axis
    By AeroKam in forum DIY CNC Router Table Machines
    Last Post: 08-10-2005, 05:05 AM
