603,320 active members*
2,670 visitors online*
IndustryArena Forum > Community Club House > Router bits for sign making
    Mar 2010
    New to CNC routing and would like some advise on a list of router bits for sign making. Am particularly interested in what the best bit is for clearing areas and leaving the smoothest flat bottom. Would appreciate any assistance.
    Mar 2003
    35494
    Depends a little on the material. For hardwoods, you'll get the smoothest surface from a carbide tipped straight bit or an upcut spiral. The problem is that they may leave a rough or chipped edge on the surface of your material. But it really takes a bit of trial and error to see what works best for you. If your V Carving, you'll want some V-bits. Sharper points for smaller letters (45° or 60°), and wider angles for larger letters (90° or 120°). If you're doing 3D carving, some ballnose or tapered ballnose.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Making a sign
    By PanhandleHammer in forum DynaTorch
    Last Post: 03-14-2010, 01:14 AM
  2. sign making
    By Drools in forum DIY CNC Router Table Machines
    Last Post: 07-28-2009, 04:57 PM
  3. SIGN Making methods?
    By esmiller in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-23-2008, 04:49 PM
  4. Sign making software?
    By jeffmorris in forum Uncategorised CAM Discussion
    Last Post: 04-02-2008, 04:33 PM
  5. BobArt for Sign making?
    By pecosjoe@yahoo. in forum BobCad-Cam
    Last Post: 10-05-2007, 05:52 PM
