Hello, this is my first post. I'm interested in having a product machined in aluminum. I have the design of a product that was originally made out of acrylic or lexan sheet. I would like the product made from aluminum. I have .dcd and .dwg files. My specifics are that the base is made from 1/2 inch aluminum and that the wheels extend approx. 1/4 inch through the base. The wheel mount can either be a thick disc with the axle bolt through it, or a thinner disk and the wheel mounted on brackets. Perhaps looking at the plans would be helpful. The .jpg was added to illustrate anothe wheel mounting option. The wheels that I will be using are 66.5mm in length.
Gareth
