587,491 active members*
4,242 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Hypertherm Plasma > Running into issue with hyperthem 45XP not cutting
    Apr 2020
    Question Running into issue with hyperthem 45XP not cutting
    Hello, my 45XP was working fine til i loaded a new sheet in and got an error that reads "LINE 4 MOVE WILL EXCEED Z AXIS LIMIT". The torch head hovers 1/2inch above the sheet. Please let me know if anyone has any idea what this means and how to fix. Thank you.
    Apr 2020
    12
    Re: Running into issue with hyperthem 45XP not cutting
    it sounds like the software limits are giving you trouble. if you have a clearance height set and your new material is thicker. and you zeroed on the material. it could now be exceeding limits set in software somewhere. and hovering above the plate almost sounds like your system is zeroed high and this could interfere with your upper limits too.
    May 2015
    686
    You need to provide greater detail about how you are creating your gcode and what your controller is/ MAch or something else?
    What doe line 4 say? what travel do you have on your z axis?
    Rod Webster
    www.vehiclemods.net.au
  1. Need Help 45xp Please
    By Lvcustomsigns in forum Hypertherm Plasma
    Last Post: 01-22-2019, 02:17 PM
  2. Hypertherm 45XP Stainless steel cutting
    By MTechEng in forum Hypertherm Plasma
    Last Post: 03-21-2017, 05:58 PM
  3. hypertherm 45xp
    By ssbadger in forum Hypertherm Plasma
    Last Post: 02-19-2017, 09:48 PM
  4. Seems Z and A axis are not running...Motor issue or Step/Dir issue?
    By Cattle in forum Mach Software (ArtSoft software)
    Last Post: 04-12-2016, 08:51 PM
  5. Raptor and hyperthem setup
    By cliff15 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 08-21-2015, 08:13 PM
