603,939 active members*
1,846 visitors online*
    Aug 2008
    56
    Running Mach3 with only X&Y Axis
    This is my first post. I want to convert a square columnn bech mill to CNC. I only want to control the x and y axes. I intend to move the z axis manually in between x and y moves. Will Mach3 allow for only x and y moves with a pause for manually moving the z? Any input on this will be appreciated. Thanks.
    Dec 2008
    9
    Quote Originally Posted by kae View Post
    Yes this is possible if you put in an M01 in the programe when you want to move the Z axis.
    M01 is an optional stop where the machine stops at this line and continues the program when you press go to continue the programe.
    You would only be able to do simple outside profiles this way you wouldn't be able to engrave or mill pockets
    Aug 2008
    56
    Quote Originally Posted by billyfriday View Post
    Thanks. I thought that it should be possible. I run a ProtoTrak at work which is only 2 axis. We find it works well for most things we do. This is also a little less expensive way to go into this. I feel I could add the z axis at a latter date.
  1. Running Mach3 with a Step four router
    By B-Sure in forum Mach Software (ArtSoft software)
    Last Post: 05-29-2022, 04:41 PM
  2. Anybody running a Taig cnc mill with Mach3?
    By squale in forum Machines running Mach Software
    Last Post: 11-03-2008, 08:30 PM
  3. running mach3
    By woodman08 in forum Machines running Mach Software
    Last Post: 02-26-2008, 05:21 PM
  4. Running flood coolant from Mach3
    By BrassBuilder in forum Benchtop Machines
    Last Post: 02-13-2008, 06:50 AM
  5. Laptops Running Mach3?
    By Fred Kelly in forum Shopmaster/Shoptask
    Last Post: 09-10-2007, 02:07 PM
