603,896 active members*
4,908 visitors online*
    Mar 2008
    161
    Running two SS on one computer
    Is it possible to run two machines from one computer and have the machines trigger events in each other's actions?
    I was thinking of maybe hooking up two SmoothSteppers and try to run two windows of Mach 3. One window for each machine.
    I wanted to automate the machining of some small parts.
    One program for the mill, and another for pick, place, and clamp.
    Any thoughts?
    Dec 2004
    1865
    Quote Originally Posted by oxford View Post
    Any thoughts?
    IIRC you can only run one instance of Mach3 at a time.
    A second computer is so cheap that it is almost not worth it anyway.
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
  1. Computer for running a CNC taig
    By Hokan in forum Taig Mills / Lathes
    Last Post: 03-10-2009, 02:17 AM
  2. What is the difference between an industrial computer and a normal computer?
    By Apples in forum Controller & Computer Solutions
    Last Post: 09-18-2008, 10:27 PM
  3. Running a gcode output file in the computer
    By Palafox in forum Uncategorised CAM Discussion
    Last Post: 06-10-2008, 11:56 PM
  4. Running Two CNC Machines On One Computer
    By Too_Many_Tools in forum Uncategorised MetalWorking Machines
    Last Post: 08-31-2007, 08:27 PM
  5. fast computer as server, slow computer as terminal
    By replicapro in forum Computers / Desktops / Networking
    Last Post: 07-01-2004, 08:05 PM
