603,890 active members*
3,118 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Search path to cutter tools - where are they stored? Why aren't they found?
    Dec 2011
    105
    I made some new tool paths with some new cutters I created in subfolders. When I try to simulate or post process, the tool path to the cutter isn't found. Is there a place where the paths are stored so that I can see what the problem is? Do all the cutters need to be in some place?
    Dec 2011
    105
    Re: Search path to cutter tools - where are they stored? Why aren't they found?
    I see that the issue is that the .ctr file must be directly in whatever directory is specified in the machine setting. Two suggestions:
    1. I would like to be able to have cutters in sub-directories under that directory. For example a "Finish" and a "Rough" directory.
    2. It would be nice if the path that is used were discoverable for debugging purposes. Ideally it could also be modified.
  1. change tools on existing tool path
    By trelos_zoi in forum MadCAM
    Last Post: 10-19-2017, 04:37 PM
  2. Cutting Alloy. I found a cheap cutter. How about you!
    By boydage in forum DIY CNC Router Table Machines
    Last Post: 02-25-2017, 01:40 PM
  3. I found the best cutter for alloy and then lost it!
    By boydage in forum CNC Tooling
    Last Post: 10-24-2014, 08:39 AM
  4. Path not found
    By jorgito316 in forum Milltronics
    Last Post: 11-18-2013, 04:09 PM
  5. cnc path not found
    By adam12000 in forum Milltronics
    Last Post: 03-16-2008, 06:51 PM
