somewhere in the polymer concrete machine base discussion there was talk of an epoxy resin which cures to be level within a few thousandths of an inch. I don't recall the name of the product but there may be other products with similar properties. My question is in regard to the mechanical properties of the resin when fully cured, how resistant to wear is it? Because of the high cost of linear rails here in Australia, I had a thought of using a broad foot print lubricated wear plate which slides over the epoxy surface. Assuming the sideways movement could be controlled it may be possible, any thoughts on this?
Splint
