587,833 active members*
3,702 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Servo Drive with Magnetic Scale Feedback
    Oct 2007
    13
    Hello all,
    About a year ago I sent the worn leadscrews on my Prolight 2000 out to be rebuilt as they had considerable backlash. This cured the backlash, but the x-screw is worn unevenly so that it can be .005 out in an inch. Rather than buy a new lead screw, I'm thinking of adding a magnetic scale to the x-axis and converting the output to mimic the 8 bit grey code of the shaft encoder on the servo shaft. Does anyone know of a reason that this wouldn't work?
    Regards
    Jan 2006
    37
    I think there are 2 things to be aware of:
    1 - resolution/accurracy of the machine willl be the same as the scale - and the servos work with some +- counts around the setpoint position.
    2 - any backlash which may come in in motor-screw-feedback system may result in unstable servo loop which is very hard to eliminate AFAIK.
  1. Which servo drive can handle AC motor without Hall feedback?
    By scsi in forum Servo Motors / Drives
    Last Post: 03-01-2017, 07:22 PM
  2. Fundamental problem with scale feedback
    By EFI-Unlimited in forum LinuxCNC (formerly EMC2)
    Last Post: 07-05-2010, 05:32 AM
  3. morbidelli MAGNETIC dc servo
    By michaeldriscoll in forum Servo Motors / Drives
    Last Post: 01-05-2008, 09:28 PM
  4. scale feedback
    By camtd in forum Mach Software (ArtSoft software)
    Last Post: 09-03-2007, 11:51 PM
  5. G320 receiving feedback from linear scale
    By Paraprop in forum Gecko Drives
    Last Post: 04-14-2007, 05:54 AM
