603,850 active members*
4,124 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Setting baud rate to 9600 on Fanuc OT
    Apr 2010
    I need to know how to set the baud rate to 9600 on my wasino lathe that has a fanuc OT controler. I need step by step instructions as I am not good at the computer part. Thanks Dennis
    Sep 2010
    1230
    Quote Originally Posted by dc123 View Post
    1. Set the Mode switch to MDI
    2. Push PARAM/DGNOS button
    3. Push a PAGE button to display the PARAMETER (SETTING 2) page.
    4. Press the cursor button to set the cursor to PWE
    5. Key in 1, INPUT, and parameters are able to be modified. P/S alarm No 100 will be displayed. This is normal.
    6. Press PARAM button to display parameters on the CRT screen.
    7. Shift the cursor to the parameter number to be changed. The parameter for Baud Rate when the I/O setting parameter on the Setting Page is set to 0, is No 552. There are two methods to position the cursor at the required parameter.
    i. Depress the CURSOR button. If this button is depressed continuously, the cursor shifts sequentially. Successive parameter pages are displayed as the cursor exceeds the last cursor of a page.
    ii. Press the button that is labeled [No. JQP], key in the parameter number and press INPUT.
    8. For a Baud Rate of 9600, key in 11 and press INPUT.
    9. After the parameter has been set, turn the screen to the PARAMETER (SETTING 2) page, and return the PWE setting to 0 by keying 0 then INPUT.
    10. Press RESET to clear the alarm that occurred when PWE was first set to 1.
    Regards,
    Bill
    Re: Setting baud rate to 9600 on Fanuc OT
    What are the Parameters for communication is supposed to be I just bought a lg7 with the Fanuc ot controller I’m having trouble getting it to accept a program with out alarming 085 or 087 I do not have the Operators manual yet but I have the rest anything would help me Tremendously
  1. Fanuc 0mc Baud Rate for DNC
    By Calmachinist in forum Fanuc
    Last Post: 08-24-2012, 09:55 PM
  2. Setting baud rate on Matsuura 560v
    By MadMan5000 in forum DNC Problems and Solutions
    Last Post: 05-16-2010, 06:33 AM
  3. Baud Rate for Fanuc System 6T
    By yumuri in forum Fanuc
    Last Post: 01-14-2010, 08:11 PM
  4. V-22 baud rate
    By qualitytool in forum BobCad-Cam
    Last Post: 10-20-2008, 02:11 PM
  5. Fanuc O-T baud rate
    By ttorqueshop in forum Daewoo/Doosan
    Last Post: 12-13-2007, 07:57 AM
