How do I set the toolpath direction in the 2D profile milling module so I can climb cut? Each time I select "Left offset" or "Comp left", it sets the toolpath to the wrong side of the profile. If I select "right offset" or "Comp right" the toolpath is on the correct side, but it verifies as conventional milling.
