587,591 active members*
3,821 visitors online*
IndustryArena Forum > Community Club House > Machinist Hangout > Sherline edge finders and wobblers
Results 1 to 6 of 6
    Mar 2017
    12
    I have my sherline running well under LinuxCNC and I am starting to check around about edge finders and wobblers. It looks like the thing to do is get a 3/8" collet and buy to that size. I bought this to continue my education while I am building the building for a real mill, so I hate to over-buy for something I will likely only use for a year or so. 3/8" shafts can probably be used when I up-grade. Any Sherline, or other micro-mill, owners out there with start up accessories advice? Am I, once again, missing something obvious?
    Feb 2010
    155
    Re: Sherline edge finders and wobblers
    I don't have a Sherline (I have a Taig), but yes it appears that most edge finders/wobblers are 3/8" or 1/2" shank diameters. To start out I would buy a manual double ended edge finder like a Mitutoyo 050103. The conical end is handy for finding the center of small holes.
    Once you get more experience with it, you might want a smart probe/edge finder, since you are using CNC.
    Nov 2008
    110
    Cheapest option - piece of drill rod with small ballbearing pressed (or glued) at end I have miniature edge finder from proxxon (with 6mm shaft) but in most cases i don't bother with using it since ballbearing is good enough and does not explode even on high speed spindle.
    Apr 2004
    5749
    Or you could buy a #2228 1/4" shaft edge finder - $15.40 from Taig: Taig Tools - Desktop Milling Machines and Lathes.
    Andrew Werby
    Website
    Feb 2010
    155
    All good solutions, but the Mitutoyo 050103 double-ended center finder is only $19 on Amazon.
    Mar 2017
    12
    going with the 3/8" edge finder and a coaxial indicator. About as cheap as I can get and still have what I need to practice getting it right. Thanks.
  1. Edge finders/touch probes
    By craigdlm in forum DIY CNC Router Table Machines
    Last Post: 01-29-2015, 05:29 PM
  2. Best and most accurate edge finders?
    By groovemixer in forum Uncategorised MetalWorking Machines
    Last Post: 03-03-2011, 02:45 AM
  3. Electronic edge finders
    By ez3022 in forum Tormach Personal CNC Mill
    Last Post: 12-12-2009, 03:22 PM
  4. Electronic edge finders - any recommendations?
    By bevinp in forum Tormach Personal CNC Mill
    Last Post: 05-21-2009, 06:44 PM
  5. Edge finders and techniques.
    By redbaron in forum DIY CNC Router Table Machines
    Last Post: 01-04-2005, 08:22 PM
