603,319 active members*
2,294 visitors online*
Results 1 to 4 of 4
    Jul 2007
    82
    shopmill to windows Siemens840D
    Hello all,
    It may be a dumb thing for some of you guys, but I don't know how to exit the shopmill on my controler and enter windows. I would like to try load drivers to use front usb to load/download programs using memory stick. Thank You for any answer...
    Feb 2009
    60
    do you want to use only windows...
    Jul 2007
    82
    Quote Originally Posted by erdinct View Post
    One of the posts on this forum says then if I will install usb driver, I don't have to use card reader (which is already dead) to upload the programs. That is the reason I'm asking for help...
    Oct 2009
    27
    If your 840D system uses a PCU20 it doesn't have windowsXP, it may be winnt4 or DOS.
    Only PCU50 / PCU70 use WindowsXP Embedded. If DOS like mine you can only plug keyboards into the USB socket. The PCMCIA slot in the PCU does take standard 1Gb CFcards with a $5 ebay adapter dependant on age of system software.
    My 810D is a PCU20 266/32, but most of the manuals seem to apply to both 810D & 840D so it would seem this PCU is used on both Systems.
    Should say on BIOS screen what PCU it is IIRC. PCU is the front end PC in the operator panel, behind screen.
  1. Shopmill - please help
    By TotalRookie in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-27-2012, 11:50 PM
  2. Windows 7 ?
    By whitehedr in forum Uncategorised CAD Discussion
    Last Post: 02-02-2010, 02:24 PM
  3. DX/32 in Windows XP...
    By albion in forum Bridgeport / Hardinge Mills
    Last Post: 10-26-2008, 01:48 PM
  4. Windows XP or Windows 2000 better with Mach2
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2004, 04:08 PM
