603,939 active members*
2,663 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > using xylotex board in combination with chinese low cost machines.
Results 1 to 6 of 6
    Feb 2006
    7
    I bought this low cost 40w laser but the software that came with it could not
    cut vectors properly.
    I had a xylotex board laying around so I tried to use it to control the laser.
    That was so easy the machine uses steppers so I unplugged from there board
    and hooked it to mine so I could control the 2 axis that was very easy.
    then I had to find a way to control the laser on/off.
    I checked there board and notice 2 wires going to the laser board with a
    +- so I check with a AA battery if it would trigger the laser and it did,
    another 15 min later I was controling the machine with turbocnc for vector
    cutting.
    I did it by using the start stop from the spindle control pin 14 on the xylotex board.
    The only drawback is that you have to modify the G-code to replace the Z
    axis movement with a M03 M05 command but possibly there maybe a software like mach2/3 that could convert that file so you don`t have to.
    Another good thing is that you keep the functionnality of the original board
    by plugging back the wires(5 min) to the original board and can engrave with there software.
    Best of both world.
    Feb 2007
    498
    what laser did you buy,and how much did it cost?
    thanks,steve
    Feb 2006
    7
    I bought the yh40 but I suppose these are pretty much all the same like the
    ie300.
    you can get them for about $1000 plus shipping.
    that is a very good price.
    the only thing is that they sometimes arrive with broken tube.
    I would suggest asking them to ship the tubes in a separate box.
    regards.
    Aug 2004
    3215
    Feb 2006
    7
    yes that is exactly the one.
    the tube was broken when i received it but they replaced it at no cost.
    it is 40w pretty powerful for the price.
    regards
    Feb 2006
    7
    I just want to say that I don`t understand why the laser machines like epilog and others are so expensive,how can you justify $10,000 a laser is so simple to manufacture.
    I think that the prices should go down dramatically in the next year.
    Anyway mine is working very good, if a board with a windows driver could be installed it would be a perfect machine.
    regards.
  1. Replies: 14
    Last Post: 03-07-2007, 12:39 PM
  2. xylotex board questions...
    By SatanKlawz in forum Xylotex
    Last Post: 11-29-2006, 10:29 AM
  3. Will a Xylotex board be any different?
    By phantomcow2 in forum Xylotex
    Last Post: 10-23-2005, 02:50 PM
  4. Chinese steppers & Xylotex
    By limbo in forum Stepper Motors / Drives
    Last Post: 04-03-2005, 01:44 PM
  5. Hooking up the xylotex board
    By yukonho in forum Xylotex
    Last Post: 01-17-2004, 06:30 AM
