603,897 active members*
2,581 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Baldo Sweo drive braking problem
Results 1 to 3 of 3
    Nov 2006
    18
    I have a 1995 HT (15 hp Baldor Sweo drive) 4020 with rigid tapping. For the most part the spindle drive works OK. The problem I have is when I do jobs that require the spindle to spin up to 8-10k rpm for a short time and then back down, the portion of the drive that provides the spindle breaking overheats and the spindle doesn't come to a stop correctly. I will stop but after coasting for a bit then jerking to a stop.
    I have been told that the sweo drive is "going out" and there's no cheap fix, just a new drive unit. It seems to me that there should be some components that can be replaced instead of the complete drive unit. When it's cool it works just fine.
    Has anybody done this or have info on it?
    Apr 2005
    1194
    No a Swea drive can be fixed very cheaply (800-1500) by this outfit
    http://www.practecllc.com/
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Nov 2006
    18
    That's awesome news, and more inline with what I was thinking to be possible.
    Thanks again.
  1. Contemplating tearing into a sweo drive
    By carbidecraters in forum Fadal
    Last Post: 01-14-2009, 09:49 PM
  2. Sweo spindle drive? new mill dead spindle
    By Shizzlemah in forum Fadal
    Last Post: 12-18-2008, 06:11 PM
  3. braking resistors.
    By najnielkp in forum Servo Drives
    Last Post: 07-07-2006, 05:03 PM
  4. sweo ac vector control problem
    By lucasv in forum Fadal
    Last Post: 03-22-2006, 04:45 PM
  5. dc motor braking
    By najnielkp in forum CNC Machine Related Electronics
    Last Post: 10-07-2005, 05:14 PM
