There is a thread in the haas forum somewhere that says about making a star shaped wiper that helps with the chips,when the chip screw turns it turns.Do a search and look it up,or maybe someone knows what I'm talking about and will point you in the right direction
.Aside from that I have found if you close off the hole on the left side of the tray around the table the chips are forced to go to the right and they seem to not float so much,so when you run the screw they they don't block the drain holes so much.
Just push the button,what's the worst that could happen.
