587,832 active members*
3,505 visitors online*
Results 1 to 8 of 8
    May 2009
    327
    First 3d toolpath
    I am going to be doing my first 3d toolpath and would love any suggestions. It is a pretty simple design with just a long bevel on the sides. I was thinking of roughing vertically and then finish horizontally. I was hoping to rough with a 3/8 endmill and finish with a 3/8 ball endmill. Again never did this so please be kind
    This is the part:
    Attachment 281826
    I am going to just do the 3d bevel and not have the cutouts done (since I can do them with a straight endmill). It is hard to tell but the bevel goes from the sides to where the extension on the top is.
    Thanks - Keith
    Dec 2009
    594
    Re: First 3d toolpath
    Personally I'd just arrange a fixture plate that could be tilted at the desired angle for those two features. Any type of 3D path will result in ridges, and the smaller the ridges the longer the machining will take.
    May 2009
    327
    I was thinking about that but for a one off piece, getting the fixture plate exactly right and everything would probably take more time than just doing it in 3d. It is too big for a vice. I can sand it afterward and get the ridges out since the 3d part is flat. I guess I am just going to have to try it and see.
    35538
    Do everything in 2D except for the face of the bevels. It's be much faster than trying to 3D the entire part.
    Jun 2004
    6618
    That would certainly reduce machine time. By a bunch.
    Lee
    May 2009
    327
    Yeah that was the plan. I was going to cut the flats all first, too. It will minimize the ball mill cutting..
    Going to do the toolpaths right now and do a test cut in wood just to make sure I don't do anything stupid...
    Dec 2009
    594
    Some CAM programs (CamBam is one) allow you to specify a sloped profile using 2.5D toolpaths.
    Mar 2011
    480
    I've used 3d scallop tool path in HSM works on several parts. It makes visually cool geometric patterns if your looking for a cosmetic type finish.
  1. 3D TOOLPATH
    By rcpilot82 in forum Mastercam
    Last Post: 05-11-2012, 03:03 AM
  2. toolpath
    By Claude Boudreau in forum BobCad-Cam
    Last Post: 02-15-2010, 10:32 PM
  3. toolpath help
    By teamjnz in forum GibbsCAM
    Last Post: 12-29-2009, 04:31 PM
  4. Toolpath
    By mopar499 in forum BobCad-Cam
    Last Post: 05-26-2009, 02:34 PM
  5. toolpath in mcx
    By craig in forum Mastercam
    Last Post: 06-01-2008, 08:58 AM
