588,287 active members*
4,625 visitors online*
Results 1 to 5 of 5
    Oct 2012
    Question Unknown G code
    What does a g code command " 28.1" do and how is it used?
    May 2004
    4519
    What machine and control?
    Aug 2011
    2517
    it doesn't exist on any Fanuc control (even the latest 32 series) but there are numerous references on the net for Mach 3, LinuxCNC etc
    here's two examples....
    G28.1 - Reference Axes | Tormach LLC | We provide personal small CNC machines, CNC tooling, and many more CNC items
    http://www.linuxcnc.org/docs/2.4/htm...8,-G30:-Return
    Oct 2012
    Machine is a plasma cutter, with a C and CNC Bladerunner control.
    Dec 2003
    24220
    It would appear that the difference in G28.1 over G28, is due to the fact that G28 is designed for machines with slow down switch and marker pulse and will return the the axis at G0 to the recorded home position, G28.1 is for stepper motor and servo systems that only use the home switch to register home and are required to see the home switch again in the G28.1.
    At least that is the way I interpret it?
    Al.
    Albert E.
  1. UNKNOWN FAULT CODE
    By CNC_BOB in forum OKK
    Last Post: 11-18-2022, 07:57 PM
  2. Unknown object
    By octaneman in forum MetalWork Discussion
    Last Post: 03-27-2012, 03:44 AM
  3. unknown
    By ajmazzsr in forum Shopmaster/Shoptask
    Last Post: 06-06-2010, 06:32 PM
  4. G65... unknown G code?
    By omgtim in forum Fanuc
    Last Post: 04-19-2010, 08:46 PM
  5. Unknown g code G23 error?
    By keaton64 in forum Mach Plasma / Laser
    Last Post: 09-22-2009, 03:33 AM
